Nog wat fotokes:
Technical Specs
Drivetrain layout Front engine, rear-wheel drive Engine type 90-degree MOD V-8, cast-iron block, aluminum heads, belt-driven supercharger with liquid-to-air intercooler Valve gear DOHC, 4 valves per cylinder Bore/stroke, in/mm 3.55 x 3.54/90.2 x 90 Displacement, in/mm 280.8 / 4,601 Compression ratio 8.5:1 Horsepower @ rpm 400 @ 6,000 (estimated) Torque @ rpm 390 @ 3,500 Redline, rpm 6,500 Transmission 6-speed manual (coupe) 5-speed automatic (convertible) Axle ratio 3.55:1 Final-drive ratio 2.24:1 Chassis Brakes Brembo 13.8-in vented disc Wheels (front) (rear) 20 in x 8.5 in aluminum 20 in x 9.5 in aluminum Tires (front) (rear) 245/40ZR20 BFGoodrich g-force T/A 275/35ZR20 BFGoodrich g-force T/A |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
